hi guys,
I am new to fvwm. I met a problem when using translucent in my config.
I first defined a colorset as follow:
[list]Colorset 7 fg Black, Translucent White 75, hi Black, sh Black[/list:u]
and when using this colorset in Menu, it works fine.
however when i try to use this colorset in other modules: taskbar, pager,buttons. It didnt work.
What’s the problem? Do the other modules only support transparent?
