Annoying newbie qustion
Hi there,
I am having trouble getting hot-keys to switch desktops. Does anyone have a really basic configuration example that allows you to switch between virtual desktops using hotkeys? I’d like to be able to have alt-{1-5} mapped to five desktops. I know this is really basic stuff, but apparently I’m THAT dumb.
Thanks a lot,
Matt
This should do the trick:
Key 1 A M GoToDesk 0 Key 1 A M GoToDesk 1 Key 1 A M GoToDesk 2 Key 1 A M GoToDesk 3 Key 1 A M GoToDesk 4
