Esteemed fellows,
Here is a short Perl script to check for new e-mail messages directly on IMAP servers, without downloading the messages.
I use it from a menu, but, with little effort, you can adapt it to open from a button.
PROS:
- Multiple mail accounts (IMAP), each one on a menu
- Any number of messages (well, if you have hundreds of new mails, you will have hundreds of menus…)
- You may have different MUAs to read your e-mail. i.e.: mutt to read mail from mail.foo.com, thunderbird for mail from mail.bar.com, etc.
CONS:
- Slow if you have a slow internet connection, or a slow IMAP server, or lots of new mails, or many accounts.
REQUIREMENTS:
- At least, an IMAP account
- Perl
- Perl module: Mail::IMAPTalk (available on CPAN):
# perl -MCPAN -e shell 'install Mail::IMAPTalk'
INSTALL:
- get the Perl script from simplicidade.com/permanente/ … ap_menu.pl;
- put the script wherever you wish;
- configure your accounts:
1 => {
SERVER_NAME => 'Foo', # Any name you wish
SERVER_ADDRESS => 'mail.foo.com',
USERNAME => 'user@foo.com',
PASSWORD => 'pass',
MUA => '/usr/local/bin/mrxvt -e /usr/local/bin/mutt',
- make it executable (chmod 755);
- add an entry on FvWM rootmenu (or other at your option)
+ "Mail" Popup MenuMail
- add the following lines to your .fvwmrc
#--------------------- CHECK MAIL ---------------------#
AddToMenu MenuMail
+ DynamicPopupAction Function MenuFvwmMail
DestroyFunc MenuFvwmMail
AddToFunc MenuFvwmMail
+ I DestroyMenu recreate MenuMail
+ I AddToMenu MenuMail
+ I PipeRead '/path/to/script/fvwm_imap_menu.pl'
#--------------------- END CHECK MAIL ---------------------#
BUGS:
- Sometimes menu doesn’t refresh. Am I missing something here?
Miguel
–> moved from Screenshots & configs[/color]
