I hope these lines below are the correct ones you want to see, because I have the configs from Pierre-Eric Marchandet and there are many config files …
Then comment it out. At this point, since all other windows are unaffected by it, I am assuming it’s a problem with nedit. To be absolutely sure of this, try a different WM completely, and load up Nedit. If the title doesn’t appear, it’s a bug with Nedit. If it DOES appear, then I’ll have to think of something else.
now I’ve tested several WMs and one DE:
VTWM: works, have titlebar and buttons.
Waimea: works, have titlebar and buttons.
KDE: works, have titlebar and buttons.
As I open nedit under fvwm an look at fvwmIdent I saw that there is no Windowname (“Untitled”) and no Iconname (“Untitled”). Then I remember, in the style.fvwmrc there is an entry “Style Untitled”
I look there and find the following:
I’ve changed it to the same style as other apps in the style.fvwm2rc:
and - what should I say - nedit has it’s own titlebar and all needed buttons
Thomas, I thank you very much for helping.
The resume about this lesson is: too much configs are the death of overview !!
I’m using fvwm 2.5.12 under Debian stable on a PIV system with 512 MB RAM. It works great (27 % memory usage after starting)
I have modified the fvwm from Pierre-Eric Marchandet. Now it has
six pagers
three bars:
one topbar for the tasks
one bottombar (it looks like the KDE-bar with a menu and six app-buttons, the pager area and a pseudo Iconbar for apps which normally appears in the KDE-systray and an area for wm dockapps like CPU, memory, soundcontrol and clock)
a modified theme called osix (MacOSx look).
Icons on the desktop (made with idesk)
Unfortunately I cannot post screenshots, cause I haven’t a homepage for the pictures, but if you look on the fvwm screenshot page you can look on Pierre-Eric Marchandets screenshots. My screen looks similar as his one. Only wallpaper and bottombar is a little bit different
I have tested some WMs, but fvwm is the greatest of all 8)
