Hey All,
Not sure if the Topic makes much sense, but the questions is this. I have a FvwmButton bar, where i want each individual button height to be 1/3 of the length.
I did a
SetEnv button_height 32
any now i want to Module to startup and to be 3 times the height of each button wide. I tried
You have things the wrong way around, anyway. You can’t just come in and out of a piperead and assume everything is preprocessed whence it left off – so in this instance, you have two options:
Dynamically create a variable containing the actual geometry.
Put the Module startup in piperead.
I’d go with 2., myself:
+ I PipeRead 'echo "Module FvwmButtons -g $(($[button_height]*3))x$[vp.height]-0+0 RightButtonBar"'
Or variations thereof. I am not in a means to test that.
