I have 2 problems with my topbar. It is a fvwmbutton with swallowed panels. I want that it look like one horizontal bar, but it show 2 vertical gray bars, the first one is one pixel width between the first and the second swallowed panel, the second one is 2 pxels width between the second and the third swallowed panel. It is no gray bar between the other swallowed panels and this is just what I want to archive if possible.
It look like that for now:
Is it some way to get ride of those 2 gray bars? I try several combinations of the panning option, but don’t get it to work. I am even not sure if the panning option is the right way to go with this.
Another issue is that, after a restart, I get the following error when clicking on FvwmButtons-Pager :
FvwmButtons-Pager: Window 0xc00003 ("FvwmPager") was grabbed by someone else (window 0x602c71)
The whole recipe I am working on is at http://rafb.net/p/ZWTN1W12.html. It is not finished, I will transform the menu button and put the audio button somewhere else. But I will first try to solve those 2 issues.
And I will remember to stat that I am using crystal for the future. Thank you for the advice.
I added a
Style FvwmStalonePanel BorderWidth 0
option for the notification aera button and the left gray bar is gone. The right gray bar is still here, but 1 pixel width instead of 2. I try to put
Style * BorderWidth 0
in order to test, but it is still here.
EDIT : It was related with a bug in stalonetray that doesn’t understand negative geometry values. To use +0 instead of ±1 solved the pixel problem.
