Confirm reboot and shutdown??
Is it possible to confirm or cancel a reboot or shutdown when I chose those options from my menu?
If I choose reboot, shutdown or logout be accident there is now way to regret this.
DestroyMenu MenuFvwmQuitVerify
AddToMenu MenuFvwmQuitVerify “Really Quit Fvwm?” Title
  • “&R. Restart” Restart
  • “&O. Log out” Quit
  • “&R. Reboot” exec sudo shutdown -r now
  • “&S. Shutdown” exec sudo shutdown -h now
  • “&C. Cancel” Nop
See the ‘FvwmForm-QuitVerify’ form that comes with Fvwm as standard.
Ok I have tried to add this:
  • “&C. Cancel” Nop
Style “*” FvwmForm FvwmForm-QuitVerify
But it still reboots etc. without confirmation
Because you misunderstood me…
Basically, you could create an item which says )in your “AddToMenu” section):
+ "&Exit" Module FvwmForm FvwmForm-QuitVerify
If you want to see what it looks like, open FvwmConsole, and type into it:
Don’t worry about exiting immediately, there’s a timer on it.
What is a FvwmConsole? In an xterm I can open write FvwmCommand but then I get this error:
user@ubuntu:~ $ FvwmCommand
No such file or directory FvwmCommand error in opening message fifo
user@ubuntu:~ $
If I want to shut down my computer and I use:
  • “&S. Shutdown” Module FvwmForm FvwmForm-QuitVerify exec sudo shutdown -h now
I get a box that says Logout, Restart, Cancel
But it should just say:
Shutdown? Cancel
without a timer. Is that possible?
It’s a module – so it can only be started by fvwm – so you should add the following line to some menu:
+ "FvwmConsole" Module FvwmConsole"
You have extraneous commands at the end of that. You want precisely this:
+ "&S. Shutdown"	Module FvwmForm FvwmForm-QuitVerify
Yep – see: man FvwmForm have fun…
In the man pages it only describes FvwmForm as a module that I can spawn like:
Module FvwmForm MyForm
But then I guees I have to make a FvwmForm module for:
reboot
shutdown
logout
if I want the text on the box to be:
Shutdown? Cancel
when I choose shutdown
And when I want to reboot I would like the text on the box to be:
Reboot? Cancel.
etc…
Is the only way to make this work to make 3 unique FvwmForm modules??
