This is my current config. I’m trying to quit shadows for my conky window, I’ve seen some configs which does.
Besides, I want rounded corners in my window decorations, how can I do them?
In my windowlist bind, I have this:
Key Tab A M WindowList (CurrentPage) Root c c IconifiedAtEnd CurrentAtEnd \
NoDeskSort NoGeometry NoCurrentDeskTitle NoCurrentPageTitle \
SelectOnRelease Alt_L
but everytime I use it, I have to give 2 Alt+Tab in order to change to the next window, and if I want to return to the last, is the same, hit twice my Alt+Tab, how can I fix it in order to hit just one time my binding?[/code]
Refering to rounded corners, Has someone of you had succes installing the patchs? I get the following error while I’m compiling.
I could patch only fvwm-snap-20060512 version.
../libs/FShm.h:19:33: error: X11/extensions/XShm.h: No such file or directory
In file included from ../libs/FImage.h:10,
from Graphics.c:34:
../libs/FShm.h:31: error: syntax error before 'FShmSeg'
../libs/FShm.h:31: warning: data definition has no type or storage class
../libs/FShm.h:32: error: syntax error before 'FShmSegmentInfo'
../libs/FShm.h:32: warning: data definition has no type or storage class
In file included from Graphics.c:34:
../libs/FImage.h:17: error: syntax error before 'FShmSegmentInfo'
../libs/FImage.h:17: warning: no semicolon at end of struct or union
../libs/FImage.h:18: warning: data definition has no type or storage class
../libs/FImage.h:22: error: syntax error before '*' token
../libs/FImage.h:24: warning: data definition has no type or storage class
../libs/FImage.h:26: error: syntax error before '*' token
../libs/FImage.h:29: warning: data definition has no type or storage class
../libs/FImage.h:32: error: syntax error before 'FImage'
../libs/FImage.h:35: error: syntax error before 'FImage'
Graphics.c: In function 'CreateRotatedPixmap':
Graphics.c:338: error: 'fim' undeclared (first use in this function)
Graphics.c:338: error: (Each undeclared identifier is reported only once
Graphics.c:338: error: for each function it appears in.)
Graphics.c:339: error: 'src_fim' undeclared (first use in this function)
Graphics.c: In function 'CreateGradientPixmap':
Graphics.c:922: error: 'fim' undeclared (first use in this function)
Graphics.c: In function 'CreateGradientPixmapFromString':
Graphics.c:1285: warning: pointer targets in passing argument 11 of 'CreateGradientPixmap' differ in signedness
make[2]: *** [Graphics.o] Error 1
make[2]: Leaving directory `/home/gustavo/dls/fvwm/install/fvwm-snap-20060512/libs'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/gustavo/dls/fvwm/install/fvwm-snap-20060512'
make: *** [all] Error 2
