This works fine:
[code]DestroyMenu MenuFVWM
AddToMenu MenuFVWM
- “%add.png%Modules” Popup MenuFVWMModules
AddToMenu MenuFVWM MissingSubmenuFunction FuncFvwmMenuDirectory - “%edit.png%Edit Config” Popup $[FVWM_HOME]
AddToMenu MenuFVWM - “” Nop
- “%refresh.png%Reload Config” Popup MenuReloadFVWM
DestroyFunc FuncFvwmMenuDirectory
AddToFunc FuncFvwmMenuDirectory I PipeRead ‘fvwm-menu-directory --dir “$0” --exec-file ^"$[EDITOR]" --xterm="$[TERMINAL]" --check-subdir’[/code]
But this doesn’t wrok
AddToMenu MenuFVWM
AddToMenu MenuFVWM MissingSubmenuFunction FuncFvwmMenuDirectoryX - “%edit.png%Edit Config” Popup $[FVWM_HOME]
DestroyFunc FuncFvwmMenuDirectoryX
AddToFunc FuncFvwmMenuDirectoryX I PipeRead ‘fvwm-menu-directory --dir “$0” --exec-file ^"$[EDITOR]" --xterm="$[TERMINAL]" --check-subdir’[/code]
And all i did is just changed 1 Character in function name everywhere.
I was messing with this entire day, till i realized that if i change function name it won’t work (or work only partially =>>> won’t open submenus, or no menus at all)
Version: 2.5.26 on FreeBSD 7
