I would like to define a variable that I can use each time I need to specify a dir.
Like a = " /home/me/apps/config"
is that possible?
is that possible?
The command you need is SetEnv, like this:
SetEnv MYVAR "My var's value"
For more info you might want to search the Fvwm manpage for it.
I have made this:
SetEnv ICONS “/home/disk10/tulsoba/.fvwm/icons/”
and then later in the file I have this:
+FvwmDock: (28x5, Frame 1,Icon ICONS"knode.png", Action (Mouse 1) Exec exec knode)
But it does not read the variable when I restart fvwm.
try “$[ICONS]/knode.png”, or add the directory to your ImagePath:
ImagePath /home/disk10/tulsoba/.fvwm/icons
Yup, although be very careful with the ImagePath as you have it listed there.
ImagePath +:/foo/.fvwm/....
You should always (regardless of anything else) prepend things to the ImagePath (hence the ‘+’), else you’ll just redefine it completely.
