Thank you very much for your reply,
Courage courage with me as newbie … We’ll make it maybe …
If I understood well, the code:
[code]#### generates a thumbnail of the current window as it’s miniicon (requires imlib2)
SetEnv fvwm_icon_width 83
DestroyFunc Thumbnail
AddToFunc Thumbnail
- I Raise
- I SetEnv MiniIcon-$[w.id] $[w.MiniIconFile]
- I ThisWindow (!Shaded, Iconifiable, !Iconic) PipeRead \
“$[FVWM_USERDIR]/scripts/thumb $[w.id] $[fvwm_icon_width] $[FVWM_USERDIR]/miniicon.tmp.$[w.id].png \
&& echo WindowStyle EWMHMiniIconOverride, MiniIcon $[FVWM_USERDIR]/miniicon.tmp.$[w.id].png \
|| echo Nop” - I Iconify
deletes the thumbnail (by using FvwmEvent)
DestroyFunc DeThumbnail
AddToFunc DeThumbnail
- I PipeRead “echo WindowStyle EWMHMiniIconOverride, MiniIcon Nop”
- I Exec rm -f $[FVWM_USERDIR]/miniicon.tmp.$[w.id].png
- I UnsetEnv MiniIcon-$[w.id]
*FvwmEvent: deiconify DeThumbnail
has to be added to my .fvwm/.fvwm2rc
and for script:
I didnt try yet …
I foudn that about thumbnail only in the .fvwm2rc:
[code]Salut les barbu de fvwm,
J’ai c’est Thumbnail, comment définir l’endroit ou il vont se placer, car la ils se placent tous le temps a gauche vericalement et je les voudraient a droite horizontal. Puis pour diminuer leurs tailles?
AddToFunc Thumbnail
- I Raise
- I ThisWindow (!Iconic) SetEnv Icon-$[w.id] $[w.iconfile]
“xwd -silent -id $[w.id] | convert -scale 128 -frame 1x1 \
-mattecolor black -quality 0 xwd:- png:$[FVWM_USERDIR]/icon.tmp.$[w.id].png \
&& echo WindowStyle IconOverride, Icon $[FVWM_USERDIR]/icon.tmp.$[w.id].png \
|| echo Nop” - I TestRc (Match) Test (f $[w.miniiconfile], f $[FVWM_USERDIR]/icon.tmp.$[w.id].png) PipeRead \
“composite -geometry +2+4 $[w.miniiconfile] $[FVWM_USERDIR]/icon.tmp.$[w.id].png \
$[FVWM_USERDIR]/icon.tmp.$[w.id].png; echo Nop” - I IconifyDestroyFunc Thumbnail
AddToFunc Thumbnail - I Raise
- I PipeRead “echo Test \(i \$\[Icon-$[w.id]\]\) WindowStyle Icon \$\[Icon-$[w.id]\]”
- I TestRc (NoMatch) WindowStyle NoIconOverride, Icon
- I Exec rm -f $[FVWM_USERDIR]/icon.tmp.$[w.id].png
- I UnsetEnv Icon-$[w.id]
- I Iconify off
- I Iconify off
Par ailleur j’ai cela pour l’attribution de la souris:
Mouse 1 R A Menu RootMenu Nop
Mouse 2 R A WindowList NoCurrentDeskTitle NoGeometry SortByClass NoHotkeys
Mouse 3 R A Menu Other
Mouse 4 R A GotoPage -1p 0p
Mouse 5 R A GotoPage +1p 0p
Mouse 2 T A Close
Mouse 3 T A Menu MenuFvwmWindowOps Nop
Mouse 4 T A WindowShade True
Mouse 5 T A WindowShade False
Mouse 1 I A DeThumbnail
Mouse 2 I A Move
Par ailleur
Comment je peut conjuger deux bouton clique gauche + roulette vers le haut ? par exemple.
J’ai appliquer ce style a firefox:
Style Firefox NoTitle, BorderWidth 0, StartsOnPage 0 1
Quand il s’ouvre il démarrage bien sur la première page, mais comment ne pas donner le focus? Car il le déplace en même temps.
En vous remerciant
ma config
(forum.hardware.fr/hardwarefr/OSA … 296-17.htm)
Thank you very much, and Greetings’
Fvwm-Newbie Patrick !
