I use fvwm-crystal, but my trayer does not seem to work. I use desktop-layout 1.1.
If I start amarok or gaim for example, the trayer does not show anything. I can’t even see the trayer itself. If I start skype I see the trayer with an icon in it, but also this happens only from time to time
I did not change anything in the fvwm-crystal configuraiton, just using standard setup.
Did you enable system tray notification for gaim. In the prefrences go to plugins and scroll down and put a check in the box. Im not sure about amarok but from what i have read in the forums here kde apps dont show up in non kde trayers. Hope that helped.
