In most instances that I’m aware of, FvwmCommand has no trouble parsing $HOME to /home/myName
But the command
FvwmCommand 'Current (*) WindowStyle MiniIcon $HOME/.fvwm/png/matlab_16icon.png'
for some reason cannot unpack $HOME
There are easy work-arounds, but it seems unlikely that this is intended behavior??
LeoSimon:
But the command
You’ve done several mistakes in your command call:
Don’t use single quotes if you use variables. Use double quotes instead.
Use $FVWM_USERDIR instead of $HOME.
2.1. FvwmCommand executes the commands the same way as in the config. So squared brackets around $FVWM_USERDIR are required, too.
Correct command string]
FvwmCommand “Current (*) WindowStyle MiniIcon $[FVWM_USERDIR]/png/matlab_16icon.png”
Hope this helps.
– Thomas –
Thanks very much, Thomas. Seems the double quotes were enough, but the square brackets generated an error. Both of these commands worked fine, but obviously the second is preferred:
FvwmCommand "Current (*) WindowStyle MiniIcon $HOME/.fvwm/png/matlab_16icon.png"
FvwmCommand "Current (*) WindowStyle MiniIcon $FVWM_USERDIR/png/matlab_16icon.png"
However,
FvwmCommand "Current (*) WindowStyle MiniIcon $[FVWM_USERDIR]/png/matlab_16icon.png"
generated:
Illegal variable name.
I thought this could be because I’m using a tcsh shell but then when I tried the command in a bash shell,
the same command generated.
bash: /home/simon/.fvwm: syntax error: operand expected (error token is "/home/simon/.fvwm")
Sorry for the wrong information about the square brackets
I don’t using FvwmCommand… Every time the same… I shouldn’t wrote something without testing…
Best,
Thomas
