I wish to implement the effect thak like the windows2000’s TaskBar, How should I do?
BTW:the versoin 2.4.19 of the FVWM has not the FVWMIconMan’s Tips style, right?
What functionality is it that windows has you wish to implement?
And yes, use 2.5.23, please.
For example,
and,
3. implement the “Show Desktop” function: when i perform the function, let all windows Iconify, and perform the function again, restore all windows’s state that before these windows are Iconify.
and My platform’s FVWM that version is 2.4.19.
#1 Using the “DontShow” option of FvwmIconMan should allow you to do this.
#2 Something like this should work I think (can’t test atm)
[code]AddToFunc MinimizeFunc
AddToFunc RaiseFunc
Unless you have a specific reason to stick to the 2.4 series I recommend you upgrade to the 2.5 series.
You can’t do “Raise,Focus” like that – you would have to call a separate function.
I already wondered about that, so I did a quick lookup in the manpage and saw something that led me to believe it could be done. I must have misinterpreted it
Thank you very much.
the question 1 is resolved already.
the resolved scheme for the question 3 that you given:
DestroyFunc ShowDesktop
AddToFunc ShowDesktop
+ I All (CurrentPage, Iconic, State 1) RestoreDesktop
+ I TestRc (Match) Break
+ I All (CurrentPage, !Iconic, !State 1) ThisWindow State 1 True
+ I All (CurrentPage, !Iconic, State 1) Iconify
DestroyFunc RestoreDesktop
AddToFunc RestoreDesktop
+ I All (CurrentPage, Iconic, State 1) Iconify off
+ I All (CurrentPage, State 1) ThisWindow State 1 False
but my Fvwm version is 2.4.19, when I run it on my system, the FvwmConsole tell me:<> No such command ‘TestRc’ & ‘State’.
can the version 2.4.19 implement the function?
then the question 2:
+ I ThisWindow (!Raised, !Focused) Raise, Focus
this code can’t correctly run on my system, the FvwmConsole prompt ‘:<> No such command ‘Raise,’’
if Fvwm’s version is 2.5.x, this should be a resolved scheme:
*FvwmIconMan: Action Mouse 1 N sendcommand IconManClicked
DestroyFunc IconManClicked
AddToFunc IconManClicked
+ I ThisWindow (Raised, Focused) Iconify
+ I TestRc (!Match) Break
+ I ThisWindow Focus
but the Fvwm that version is 2.4.19 how to implement this function?
additional, this code:
is inefficacy to the current window, the reason is the current window don’t match the condition '(Raised, Focused) '.how should I do?
my platform is openbsd, so i still used the version 2.4.19. I think, if it is fit, that it is good.
Well, while 2.4.x is still supported officially you’ll find that very few people actually know it, so if you require support I’d recommend upgrading to 2.5.x as that is what most people use.
State and TestRc don’t exist in 2.4.X – you can use CondRc though in lieu of TestRc, but there’s no concept of State in 2.4.X, yet another reason to use 2.5.X really.
As I told you previously, you can’t apply Raise and Focus that way, instead either call another function as in:
+ I ThisWindow (!Raised, !Focused) RaiseFocus
DestroyFunc RaiseFocus
AddToFunc RaiseFocus
+ I Raise
+ I Focus
But by this point this is irrelevant since you need 2.5.X anyway.
