I have 2 functions that I use to update my FvwmBackerDesk background from a menu:
SET DESK COLOR
AddToFunc SetDeskColor
I *FvwmBackerDesk $0 -solid $1
I *FvwmPagerDeskColor $0 $1
SET DESK IMAGE
AddToFunc SetDeskImage
I *FvwmBackerDesk $0 Exec exec xloadimage -onroot $1 &
I *FvwmPagerDeskPixmap $0 $1 &
I was hoping that this would also update the FvwmPager, but it doesn’t work. The backer updates but the pager stays its original color. Is this a bug? Am I doing something wrong?
Thanks for the reply. I don’t have a problem setting the backgrounds on startup. That all works fine. What I’m trying to do is change the pager and desk backgrounds interactively from a menu after everything is already build. Any ideas on that?
