Hi all:
Dumb question, and a simple yes or no would work right now:
Is it possible to place icon’s (gif’s, jpg’s, etc) in the FVWMTaskbar?
I think it is, but just had the thought and wanted to ask…
Thanks in advance,
- Skender
Hi all:
Thanks in advance,
If you mean a mini icon of an application as the title of a window, then yes it is.
If, however, you meant something like a system tray effect (some applications do provide such things), then you will need to use an external application such as ‘trayer’, or ‘xystray’, etc.
thomas –
that’s exactly what I was thinking about.
thanks for pointing me in the right direction…
cheers,
Skender
