Just like the topic how do i get swedish letters in fvwm?
I suppose that using an xft font that supports swedish should do the trick, an utf8 font will probably also be fine, see man FvwmTheme for more info on the ways you can specify fonts. (I don’t have access to it atm, so I can’t look at it for you…)
Fixed it i used
encoding=UTF-8
Thanks for the hint
