GotoPage Automatic
How to switch to the PAGE which contain the focued window automatic when I use ALT+TAB to focus a window.
What do you mean? That’s implied by Focus/FlipFocus unless you use “NoWarp” as an option.
NOT that mean.
I mean the FvwmPager, the function like GoToPage.
when I use ATL+TAB to focus a window, It can not GoToPage that contain the focused windows.
Sorry for My poor english.
So you probably mean WarpToWindow, although by default the WindowList function looks like this:
AddToFunc WindowListFunc
+ I Iconify off
+ I FlipFocus
+ I Raise
+ I WarpToWindow 5p 5p
So I fail to see what your problem is. Unless you’re not using that definition above?
Thanks.
I add this to the WindowListFunc
  • I WarpToWindow 50 50
The problem has been solved.
