So, specifically, my audio player Audacious (though evince and all other GTK apps do the same thing) will forget the location of the pointer once I primary-click with a mouse set to left-handed use.
I enter the command: xmodmap -e “pointer 3 2 1 4 5 6 7 8 9”
and click the top of the window to move it. Now, if I click anywhere else, it does not accept the new pointer position until I secondary-click.
This is also sometimes the case with setting a right-handed mouse with ‘xmodmap -e “pointer 1 2 3 4 5 6 7 8 9”’
This has only recently (as of about 1. December) been a problem (though, as a gentoo user, there’s a bit of delay in versions).
Anyway, can you advise on what’s going wrong?
Thanks,
EE
Same question, I see…
You’ll need to be more specific – how are you moving the window, what behaviour is it you’re seeing which you don’t like? I still can’t quite guess from your description WTF you’re on about.
ohai there! Nice to see some other gentoo people here. Anyway, here’s exactly what I do:
- xmodmap -e “pointer = 3 2 1 4 5 6 7 8 9” is in my .xsession file, setting the mouse left-handed on login.
- I start Audacious (for example; it could be evince as well)
- Audacious has a playlist window, which I have set open. The playlist does not have a separate icon in IconMan, nor does it appear on the pager (if that matters)
- I primary-click the title bar of either window of Audacious, and drag it into position (in the corner or whatever).
- from this point on, Audacious will respond as if the pointer is still positioned over that window’s title bar, regardless of where else on either window I click
- to re-set the pointer position, I have to secondary-click somewhere on either window
- this behavior persists even if I change to a different desktop and back, interact with other windows, etc.
- If I set ‘xmodmap -e “pointer = 1 2 3 4 5 6 7 8 9”’ from the console (or in .xsession), this behavior does not occur (but now the mouse is right-handed, which I do not want).
So far as I can tell, this occurs only with gtk apps, only under fvwm, and only since about 1. December (or therabouts; I don’t restart my wm every day).
I hope that clarifies the situation a bit. Any guesses what’s going on here?
Thanks,
EE
arrgh! I spoke too soon: this also occurs under GNOME. so, uh, crap. I guess this isn’t a problem specific to fvwm. Shall we move back to the gentoo forum?
Sorry for the cross-post shame
EE
Get come xev(1) output for the window you’re moving. But at this point, unless it’s FVWM’s problem, I care not to look in to it.
I am not a Gentoo user, by the way.
