Pretty new to fvwm, been poking through the man page between trying to work…
I’m trying to understand the relationship between borders and handles. If I understand correctly, handles are just the things in the corners (grips?), and if the are present, then the border gets its style from the handles. Assuming that is correct:
can you set a style for one side of the border, such as making the bottom border bigger or a different color?
Is it possible for the handles to be a different color than the border? and different width?
HiddenHandles doesn’t seem to be working for me, I have it as
+ BorderStyle HiddenHandles
in the Decor that I’m using. Is that not right? How to get rid of the line.
Did the patch allowing four borders to be different get merged? If so, how to enable the style? If not, are there alternative choices? Sorry, I am newbie and not familiar to the manual of FVWM (especially the section of Style, which is difficult to search for keywords).
