Help needet with key bindings (especially to whitespace)
I want to start a program (dmenu) when pressing + but I don’t know how to define this.
I found out that space has the keycode 65 using xev but i don’t know how to bind this in the config.
I now do know that I can bind the “Windows” key with
Key <some-key> A   4
But I don’t know why I have to use the “4” here. (Normally I use just an “M” to bind it to my ALT-Key).
It would be great if you can tell me where I can find more about these bindings and how to bind +…
Thanks a lot!
Key Space A C SomethingToRun
See “xev” for how to get the keysyms.
