Hi All,
I’m looking for a way to make my FvwmButtons panel invisible (and then visible if needed).
I tried to do it with a Layer command but no luck.
Any suggestion is very appreciated.
Thanks a lot in advance
Best regards
Cmpayc
Hi All,
Best regards
Cmpayc
Invisible in what way? As it’s FvwmButtons you have some options:
Panelise it. That is, make it retractable with a little button that makes it popup again. (See ‘Man FvwmButtons’ for more information.
You can autohide it. See:
fvwm.org/documentation/faq/#7.17
Style myFvwmButtonsName NoIcon
Which means that when it is minimised I won’t see it in the root desktop. As for hiding/unhiding it, I do so by triggering an event that happens when my mouse hits the bottom of the screen, as in:
EdgeCommand Bottom All (myFvwmButtonsName) Iconify
Key Q A CS All (myFvwmButtonsName) AnimatedMove -5000 -5000
(Yes, the location is exaggerated, and yes I realise that’s not a toggling action, but search these forums for ‘toggling’ and that will yield some answers.)
Is that enough ways?
Hi Thomas,
Thanks a lot for Your suggestions.
It is more then enough ways
I did it with NoIcon style-options and Iconify-command, it works fine.
I decided to do it on this way, because I’m traying to make a fvwm-config for my Linux PDA (Sharp Zaurus) and prefer to work with the keyboard not with the touch-screen.
Another possibilities are very interesting as well, especially when I will make the config for PDA-Mode (keyboard can not be used, only the touch-screen).
Best regards
Cmpayc
