Hello, i don’t success to make different menustyle ! I have 2 themes and i would like have a different menu for each one.
Here it is a function that load one of my theme, as you can see i only change the colorset of the menu :
No for exemple, if i want to change the ItemFormat, it doesn’t work.
I can change all style i want and then use UpdateStyles and it works but nothing for the menu.
