mousebindings (mouse button combos)
Is that possible? For example, I am thinking about getting a mouse with the 6 + 7 back and forward buttons. Could I make 7 + scroll up/down change the volume?
Not that I know of, but you can use a modifier all the same. It should be pointed out that a mouse with 5 buttons is fully supported – anything above that (so your buttons 6 and 7) may only partially work.
– Thomas Adam.
right… but that is 6 and 7 including the scroll. I know that there is a button rescrition.
I would like to emulate some of the functions of this mouse. esp, the volume since i usually have my tv sound running through my computer sound card.
fvwm.org/documentation/faq/#6.8
