I’m having trouble moving an FvwmIconMan offscreen on startup. There are 2 FvwmIconMan’s running called IManUp and IManDown. When “All (IManDown) Move -30000 -30000” is executed from FvwmConsole, it moves offscreen as expected. But when executed from the start function IManDown stays on screen.
I PipeRead “$[ConfigPath]/create_iconbuttons.sh”[/code]
I have already tried something like:
[code]AddToFunc StartFunction
I Module FvwmIconMan some_alias
I Wait some_alias
I Next (some_alias) Move foo bar [/code]
And it didn’t work, either. But I’ll give it another try. I thought that “+ Wait IManDown” would insure that it was on screen before trying to Move it.
Skip
Heh. It would work if the alias supplied to FvwmIconMan was the actual name of the window. It isn’t – and the ‘Wait’ command works by title only. What you need to do is:
[code]
I Wait FvwmIconMan
I Next (FvwmIconMan) Move foo bar [/code]
Of course, that won’t help you distinguish between two different instances of FvwmIconMan. The only way I can see you getting around this is to swallow one of them in FvwmButtons, and to use the alias of the FvwmButtons as the matching condition to ‘Wait’ and ‘Next’.
I consider FvwmIconMan not setting it’s WM_NAME to that of an alias a bug, quite frankly.
The following appears to work (it waits for the other FvwmIconMan [IManUp] instead of IManDown). I have another work around as well using WarpToWindow and FvwmAuto which I prefer to swallowing in a button.
I Module FvwmIconMan IManUp
I Module FvwmIconMan IManDown
I Wait IManUp
I All (IManDown) Move -30000 -30000[/code]
Thanks for your help again, Thomas.
Skip
