move to screen button and maximazation
ok so I have two monitors (both 1280x1024) and EwmhBaseStruts is set to stop 48 pixels from the bottom on both screens
but on the secondary monitor its set to stop 180 pixels from the right (for fvwmbuttons) my fvwm decor has four buttons on the right (from right to left) ‘close’, ‘maximize’, ‘iconify’, and the ‘movetoscreen’ buttons
DestroyFunc Fvwmmovetoscreen
AddToFunc   Fvwmmovetoscreen
+ M nop
+ C Fvwmtoscreen $0
+ D nop
DestroyFunc Fvwmtoscreen
AddToFunc   Fvwmtoscreen
+ I Maximize
+ I movetoscreen $0
+ I Maximize
DestroyFunc FvwmIconifyOrShade
AddToFunc   FvwmIconifyOrShade
+ C Iconify
+ D WindowShade
DestroyFunc FvwmMaximize
AddToFunc   FvwmMaximize
+ H Nop
+ M Nop
+ C Maximize $0 $1
DestroyFunc FvwmMoveOrIconify
AddToFunc   FvwmMoveOrIconify
+ M Move
+ D Iconify
+ Mouse 1 2 A FvwmDeleteOrDestroy
+ Mouse 1 6 A FvwmIconifyOrShade
+ Mouse 1 4 A FvwmMaximize 100 100
+ Mouse 2 4 A FvwmMaximize 0 100
+ Mouse 3 4 A FvwmMaximize 100 0
+ Mouse 4 T A FvwmWindowShade True
+ Mouse 5 T A FvwmWindowShade False
+ Mouse 1 8 A Fvwmmovetoscreen 0
+ Mouse 3 8 A Fvwmmovetoscreen 1
+ Mouse 3 T A Menu FvwmWindowOpsMenu
the first problem is that the ‘movetoscreen’ button only works if the window is maximized(if I take the maximization commands out then I have to re-maximize the window after its moved), the second is that I would rather have the window move to the next screen on mouse 1, like the Nvidia button, and when I de-maximize the window it goes back to the screen it was on
Nonsense.
Here’s how you ought to have written it:
+ I movetoscreen $0
That way you don’t care about maximisation at all. If though you wanted it to be maximized only after moving the window then:
+ I movetoscreen $0
+ I ThisWindow (!Maximized) Maximize
Or, if you wanted it such that it would maximize the window if it wasn’t already before moving the window then shift the test to the top:
+ I movetoscreen $0
See the last example of mine, above.
not what I had in mind but it helped
+ I  movetoscreen $0
+ I ThisWindow (Maximized) Maximize true 100 100
this works perfectly
So it was what you had in mind then… you’re using it.
Oh, and you’re very welcome.
