Another update:
z07.zupload.com/download.php?fil … epath=2237
** FEATURES **
* Configure wallpapers, decorations, colorsets, fonts, panels, icons and
menustyles with just one click.
* Transparent and solid themes.
* An alt-f2 launcher made out of an rxvt, no gtk, no qt, no nada. Very light
but much more functional than one of these fancy command launchers,
because you get all the benefits of bash.
* 7 different panel modes, the panelized stuff goes out in an animated
fashion. Three big panels, three thing ones, one text mode ultra-thin
panel and also one config for no panels at all.
* A FvwmScript clock. Also themed by the menu colorsets and fonts. Also
included are applets to control the master volume, watch the temperature
of your micro, and control xmms.
* Buttons in the title to close, WindowList, minimize and maximize. Midle
click in close destroys the window (I could not live without this),
right in maximize maximizes height, middle maximizes weight. This
behaviour is defined in the deco, so, if you dont like it, edit any
deco under ~/.fvwm/decorations/ and save it with another name, it
will automatically be shown in the configuration menu.
* Fancy useless desktop thumbnails (yes, fast imlib2 based thumbnailing)
and not less useless wallpaper thumbnails in the menus.
* Six pages, 3x2, in one desktop.
* Win key is used in most bindings. Ctrl-alt-z fast restart.
* Window options menu and Exit Form when middle
click the fvwm logo.
* Shade wins with wheel in the title. A second wheel can be used to resize the
window (over the title also).
* FvwmForm-QV to exit, restart and xlock for the lock function. Win+l also
locks the screen.
* Middle click into an app in iconman goes to it (even if it is into any other
page. Left maximizes and minimizes, right shows the window menu.
* SloppyFocus, the viewport automatically moves when you reach the screen edge,
and my value for that property is pretty sensible, I like it that way.
* Full icon hover/pressed state support in the FvwmButtons bar.
* Device applets, lclick opens in rox, middle in mc, and right opens menu.
* Right click menu for the device applets contains a list of players, and an
option to edit the players links folder and the icons for those. So, adding
a new element to that menu is just a matter of dropping some links into
a rox window. Easier way ever to configure fvwm ;)
* Default icon set made out of the excelloent RAD.E8 iconset (Graphitte).
CHANGELOG
*** 27, nov-2005: version 1.0 ***
* Bugfixes.
* Added 16 pix, iconset. Exactly the same iconset, just smaller.
* Added default option to the configuration menu. This will reset
the theme to the default white-flat one. And will clean the
wallpapers cache and some other things. So, you can use too
if you changed the contents of some of the wallpapers. They will
be recreated again the next time that you open that menu.
* More revisions in the colorsets. Specially the gradient ones.
Fixes in the applets colorsets. Most now include a fully
transparent colorset for the applets, so it might take a bit
more resources, but they display ok over the gradient of the
taskbar. No changes in the plain colorsets.
* Added right click menu for the device applets.
* Smaller volume and temp applets, added xmms controls.
The clock now shows more info.
* Some icons added/changed.
* Dropped CS_clock, CS_Applets includes now the clock.
