It doesn’t say anything about this in manual. Is there a length limit for PipeRead’s '“command”?
No more so than what the underlying shell accepts as input. Which is either /bin/sh or whatever you’ve set ExecUseShell to. Note that if you have to ask this, you’re doing it wrong and you should write a script as a separate program.
I’ll always test the script in a shell file or a terminal. Then I put it in a PipeRead command, and if it doesn’t work I test it with Echo.
Echo "Do Not Worry, This Is Just A Test Line 1;\
Do Not Worry, This Is Just A Test Line 2;\
Do Not Worry, This Is Just A Test Line 30"
It stops at line 25, then:
[fvwm][__execute_function]: <<ERROR>> No such command 's'
[fvwm][__execute_function]: <<ERROR>> No such command 'Do'
Then your original question doesn’t accurately relfect what you’re trying to do. Please provide an actual example of something using PipeRead and stop pasting snippets.
DestroyMenu FvwmProgramsMenu
AddToMenu FvwmProgramsMenu "Programs%$[fvwm_icons]/places/programs.png%"
PipeRead 'app_categories=(Network AudioVideo Office Graphics Game Education Development System Settings Utility);\
menu_categories=(Internet Multimedia Office Graphics Games Education Development System Settings Utilities);\
for i in {0..9}; do\
categories_icons[i]=$(echo ${menu_categories[i]} | tr A-Z a-z);\
done;\
echo + \\"\\" Nop;\
[[ $(grep "Categories=.*${app_categories[0]}.*" $(find $fvwm_apps_path/*)) != "" ]] && echo + \\"${menu_categories[0]}%$fvwm_icons/places/${categories_icons[0]}.png%\\" Popup InternetAppsMenu;\
[[ $(grep "Categories=.*${app_categories[1]}.*" $(find $fvwm_apps_path/*)) != "" ]] && echo + \\"${menu_categories[1]}%$fvwm_icons/places/${categories_icons[1]}.png%\\" Popup MultimediaAppsMenu;\
[[ $(grep "Categories=.*${app_categories[2]}.*" $(find $fvwm_apps_path/*)) != "" ]] && echo + \\"${menu_categories[2]}%$fvwm_icons/places/${categories_icons[2]}.png%\\" Popup OfficeAppsMenu;\
[[ $(grep "Categories=.*${app_categories[3]}.*" $(find $fvwm_apps_path/*)) != "" ]] && echo + \\"${menu_categories[3]}%$fvwm_icons/places/${categories_icons[3]}.png%\\" Popup GraphicsAppsMenu;\
[[ $(grep "Categories=.*${app_categories[4]}.*" $(find $fvwm_apps_path/*)) != "" ]] && echo + \\"${menu_categories[4]}%$fvwm_icons/places/${categories_icons[4]}.png%\\" Popup GamesAppsMenu;\
[[ $(grep "Categories=.*${app_categories[5]}.*" $(find $fvwm_apps_path/*)) != "" ]] && echo + \\"${menu_categories[5]}%$fvwm_icons/places/${categories_icons[5]}.png%\\" Popup EducationAppsMenu;\
[[ $(grep "Categories=.*${app_categories[6]}.*" $(find $fvwm_apps_path/*)) != "" ]] && echo + \\"${menu_categories[6]}%$fvwm_icons/places/${categories_icons[6]}.png%\\" Popup DevelopmentAppsMenu;\
[[ $(grep "Categories=.*${app_categories[7]}.*" $(find $fvwm_apps_path/*)) != "" ]] && echo + \\"${menu_categories[7]}%$fvwm_icons/places/${categories_icons[7]}.png%\\" Popup SystemAppsMenu;\
[[ $(grep "Categories=.*${app_categories[8]}.*" $(find $fvwm_apps_path/*)) != "" ]] && echo + \\"${menu_categories[8]}%$fvwm_icons/places/${categories_icons[8]}.png%\\" Popup SettingsAppsMenu;\
[[ $(grep "Categories=.*${app_categories[9]}.*" $(find $fvwm_apps_path/*)) != "" ]] && echo + \\"${menu_categories[9]}%$fvwm_icons/places/${categories_icons[9]}.png%\\" Popup UtilitiesAppsMenu'
OK, I can put all this in a for loop, but the script is longer.
Works for the first three categories, then “<> No such command”.
Yes – you’re failing.
Here is little something for you, from Russia with love: pastebin.com/ktGaAcgw
I’m not the author, but I use this handy little thingie.
It depends on gnome-menus, but I mostly use gnome/gtk soft, so…
The only trouble is 'Sound & video" item handling. )
The author says it can be used as a pipe menu script, but as I do not install new application every week, I just run it once redirecting the output to a configuration file.
//In archlinux python stands for python3, so if your disto ships python 2 by default, change the interpreter call.
How about we don’t do this, with the overhead of python, and fix the shellscript – the solution of which is immediately obvious when you run it as a shell-script.
How about we get things done and go watch movies or play nexuiz?
I’ve made my own programs menu generator script, using desktop entries from /usr/share/applications:
appsmenu="/home/.fvwm/files/appsmenu"
cat /dev/null > $appsmenu
for catID in {0..9}; do
categories_icons[catID]=$(echo ${menu_categories[catID]} | tr A-Z a-z)
done
echo + \"\" Nop >> $appsmenu
[[ $(grep "Categories=.*${app_categories[catID]}.*" $(find $fvwm_apps_path/*)) != "" ]] && echo + \"${menu_categories[catID]}%$fvwm_icons/places/${categories_icons[catID]}.png%\" Popup ${menu_categories[catID]}AppsMenu >> $appsmenu
done
echo >> $appsmenu
echo DestroyMenu ${menu_categories[catID]}AppsMenu >> $appsmenu
echo AddtoMenu ${menu_categories[catID]}AppsMenu \"${menu_categories[catID]}%$fvwm_icons/places/${categories_icons[catID]}.png%\" >> $appsmenu
echo "+ \"\" Nop" >> $appsmenu
for i in $(find $fvwm_apps_path/*); do
if [[ $(grep "Categories=.*${app_categories[catID]}.*" $i) != "" ]]; then
app_name=$(grep "^Name=.*" $i | sed -e "s/Name=//" -e "s/[0-9]\+\(\.\| \|$\)//g" | cut -d " " -f 1-2)
app_icon=$(grep "^Icon=.*" $i | sed -e "s/Icon=//" -e "s/.*\///")
if [[ $(echo $app_icon | grep -o "\.") == "." ]]; then
app_icon_name=$(echo $app_icon | sed -e "s/\..*$//")
app_icon_ext=$(echo $app_icon | sed -e "s/.*\.//")
else
app_icon_name=$app_icon
app_icon_ext=png
fi
if [[ $(ls -t $fvwm_apps_icons/*/32x32/*/$app_icon_name.png > /dev/null 2>&1 && echo true) == "true" ]]; then
app_icon_path=$(ls -t $fvwm_apps_icons/*/32x32/*/$app_icon_name.png | head -1)
else
if [[ $(ls $fvwm_apps_pixmaps/$app_icon_name.$app_icon_ext > /dev/null 2>&1 && echo true) == "true" ]]; then
convert -resize 32x32 $fvwm_apps_pixmaps/$app_icon_name.$app_icon_ext $fvwm_temp/$app_icon_name.png
app_icon_path=$fvwm_temp/$app_icon_name.png
else
app_icon_path=$fvwm_icons/apps/32x32/program.png
fi
fi
app_exec=$(grep "^Exec=.*" $i | sed -e "s/Exec=//" -e "s/\"//g" -e "s/\'//g" -e "s/ -caption//g" | cut -d "%" -f 1)
[[ $(grep "^NoDisplay=.*" $i | sed -e "s/NoDisplay=//") != "true" && $(grep "^Terminal=.*" $i | sed -e "s/Terminal=//") != "true" && $(grep "^OnlyShowIn" $i) == "" ]] && echo + \"$app_name%$app_icon_path%\" Exec exec $app_exec >> $appsmenu
fi
done
echo >> $appsmenu
done
Where:
fvwm_apps_path=/usr/share/applications
fvwm_apps_icons=/usr/share/icons
fvwm_apps_pixmaps=/usr/share/pixmaps
So, because I’m failing at putting it in a PipeRead command, I’ll use it as a shell script file.
