I resize windows with Alt + Right Mouse (like blackbox,wmkaer etc), and have two small issues…
I get the rubberband and can’t make window smaller unless i’ve tried make it bigger first. The rubberband is stuck at the windows original size. I hope you know what I mean by rubberband
Everything locks during the resize. After a second or so, everything stops until i release the mousebutton. For instance bmp pauses the music or if a movie is playing (mplayer) it also pauses.
Maybe this has been posted before, but I didn’t find it. I’ve been using fvwm for years and really like the configurability but this is making me nuts!
I think no one answered this yet. You can specify a direction to the Resize command and then the resize will start automatically. I have for example this binding:
Mouse 3 WSFT 3 ResizeM
DestroyFunc ResizeM
AddToFunc ResizeM
+ M Resize Direction SE
for resizing inside of a window with the super key. This means of course that you always resize “dragging” the lower right corner. For me that is not a problem, but for a colleague of mine I wrote this function:
