Just tryin’ out fvwm, being a long time gnome user …
I’m trying to edit the default config, just to get me goin’, and then copy some parts
from other themes, to create the *ultimate" theme
Anyways, I’m kinda stuck. I just can’t get the root-menu to change colors
This is what I’ve added to .fvwm/menus:
Play about with the numbers in the above, so that you assign the correct colorset numbers, depending on which one is for which effect. The first option to menucolorset will probably be the one you want to change, anyway.
