Hi, I would like to be able to set a key binding from within an fvwm session. (I don’t want the command to be in the bindings file because it uses environment variables set after bindings has been read by fvwm). I would have thought the way to do this was to use FvwmCommand, e.g., after assigning values to the env variables STD_COLS and STD_ROWS, I’d like to run
FvwmCommand 'Key F4 A A Exec xterm -geometry $STD_COLS\x$STD_ROWS'
but this just generates what appears to be FvwmCommand’s favorite response to everything
Is there some way to make this work. Alternatively, is there a way to get fvwm to read a bindings file once the session has begun?
Thanks for any suggestion!
