I have just started using this program called xtu. Heres a link to the site
http://www.core.de/~coto/projects/xtu/
Now for some reason it stays on to of all other windows. When i try to get the window id or the resource name so i set a style to have it on bottom it wont let me click on it. Like its part of the root window or something. If i use xwininfo i get this
[code]xwininfo: Window id: 0xe00015 “xtolleuhr”
Absolute upper-left X: 935
Absolute upper-left Y: 653
Relative upper-left X: 935
Relative upper-left Y: 653
Width: 90
Height: 90
Depth: 16
Visual Class: TrueColor
Border width: 0
Class: InputOutput
Colormap: 0x20 (installed)
Bit Gravity State: ForgetGravity
Window Gravity State: NorthWestGravity
Backing Store State: NotUseful
Save Under State: yes
Map State: IsViewable
Override Redirect State: yes
Corners: +935+653 --1+653 --1-25 +935-25
-geometry 90x90–1-25
So how would i go about getting the resource id i need to set a style for it? I thought that “xtolleuhr” might have been it but it doesnt seem to be working. So im at a lose on what to try next.
VoiDeR
