I think this problem is more complicated for me to describe than it is to solve, at least for me that doesn’t have english as a natural language, but i try my best to be as detaljed as possible here.
I have adopeted and rewritten (quite much) some code to have a full screen fvwmpager with previewed miniicons of running programs
Also i have a fvwmpager that shows up when i hit any edge of the screen.
The Problem is, if i want to use both - i got locked with the big pager, The programs in the big pager are clickable and shows up, but the big fvwmpager never dissapair.
This doesn’t tells much about my problem, eh.?
To be more specific - here is Screenshots and code
First - my config file
IgnoreModifiers L25
Mouse 3 R N FuncGotoPager
read /home/peter/.fvwm/Misc_1
read /home/peter/.fvwm/DeskTopS
read /home/peter/.fvwm/BigPager
#read /home/peter/.fvwm/EdgePager
This One works well if i not have The FvwmPagerEdge (that resist in the file EdgePager -i will clean that up the names in the future) activated at the same time
picture: img212.imageshack.us/my.php?imag … gervp4.png
code: rafb.net/p/HADhwX23.html
Also i have a config file for a Fvwmpager that pops up when i hit any edge if the screen, its named differently to not disturb/get disturbed of the other fvwmpager configuration.
To use it - i have to swap the comment
#read /home/peter/.fvwm/BigPager
picture: [img214.imageshack.us/my.php?imag ... gerzg4.png](http://img214.imageshack.us/my.php?image=edgepagerzg4.png)
code: [rafb.net/p/vobVNG74.html](http://rafb.net/p/vobVNG74.html)
I use a file for the default Settings for desktops backgrounds and such
code: rafb.net/p/6Y7PJO89.html
My target is to have full screen pager to pop up when i rightclick on the desktop and when i hit the edge the other pager (FvwmPagerEdge) shall pop up.
So then i uncomment both Lines in my config.
[/quote]
But, there comes my problem
code: img338.imageshack.us/my.php?imag … gerkd1.png
As you can see, i have the EdgePager in the bottom of the screen (i had the mouse there so it showed up there) and the fullscreen FvwmPager both at same time, that is how they shows up when i start/restart fvwm - and i dosn’t seems to get the big pager to dissapair, . But the running programs are still clickabele and shows up, as you can see on the terminal window.
Also, i made a smaller version of the Big sized fvwmPager - in the file BigPager i swapped
*FvwmPager: Geometry $[FvwmPagerWidth]x$[FvwmPagerHeight]+0+0
# *FvwmPager: Geometry 360x360+0+0
to
# *FvwmPager: Geometry $[FvwmPagerWidth]x$[FvwmPagerHeight]+0+0
picture: [img338.imageshack.us/my.php?imag ... eparp4.png](http://img338.imageshack.us/my.php?image=bigpagermadesmalledgeparp4.png)
The problem is still there, with the only change that i now can access the desktop because the Big fvwmpager now has become smaller…
About this line in my config.-file
ahh, the only code in there is
Style "*" ClickToFocus
Which i needed to access scrot when my terminal window not was in focus to get the photos for this story
