right now a FvwmIconMan gets swallowd by a FvwmBar. but the tasks always get sized over the whole width of the bar. how can i get a fixed width for each task. something this: fvwm.org/screenshots/desktop … enshot.jpg
task. something this: fvwm.org/screenshots/desktop … enshot.jpg[/code]
You want to use FvwmIconMan, and probably want to set:
*FvwmIconMan: MaxButtonWidth width
in my config. adding the second line makes no difference. the whole bar gets divided up by the amount of tasks. if i only have one task, it gets stretched all over the complete width of the bar. if i got 10 tasks, they get pretty small. what i would like to have would be tasks with a fixed width.
If I am correct these options were added relatively recently to Fvwm, so if you’re not running the latest 2.5 series version it might just not be recognized.
As a sidenote to all who read this: we’ll always assume you’re using the latest release unless told otherwise, so if something doesn’t work, first and foremost check your Fvwm version
Well, I know that it’s something I will assume, unless told otherwise. Of
course, the posting guidelines to these forums do request that when asking a
question, that the poster does state their FVWM version…
