Hello everyone! I’m working on my first fvwm config and I did most of the things I wanted to do, but… I have three questions and I cannot find answers googling or searching the forum, so…
1. I’m using RoundedCorners patch and it’s working perfectly, except for menus (but I’m sure menus corners can be rounded, I’ve seen it here). Maybe some other setting may interfere whit RoundedCorners? Or maybe menus has to be set in some other way? Or maybe I have to install/patch something else? I have tryed the config of the link I’ve posted but that one doesn’t work too.
2. Is it possible to have a sort of double border as window decoration? I’ve read about MultiBorder, or pixmap, but I’m not sure that’s what I need and, most important, I haven’t found any example code to try. You can see my actual borders in the screenshot below, but I would like to set them like in this one.
3. Can I set the look of every application to be the same? As you can see in the screenshot below, some apps have a sort of default window style (gray and square), while kde apps have the style I set for them using kde config tools (lighter gray and more smooth).
Any help (a code snippet, an rtfm whit a link, some better keywords for search, a pat on the back…) would be greatly appreciated
I will search about those shaped colorsets. It’s a pity for the borders but I like them this way too, so… I’ll not die for this.
I supposed that window style was depending by gtk and qt settings but I was not sure, because I’ve noticed that using xfce all windows had the same style but well… I’ll go search some matching themes.
Thanks thomasadam for your fast and helpful reply.
