Hi, I want to turn off fvwmbuttons and use WinListDesk. (Is Fwmbuttons
what controls the “norm” icons that end up in, say, an “IconBox”?)
I commented fvwmbuttons out of everything I could find, but when i
restart, there they are. Of course when I hit
settings>app-manager>winlistdesk the buttons turn off and WinListDesk
works fine. How do I turn FvwmButtons off?
I guess i didn’t ask this properly so i’ll try again.
Current Setting:
Background: xsetroot -solid Cyan4
Start WinListGlobal
No Buttons Bar
Start FvwmButtons DeskerPanelButtons
Do not start MiniButtons
Do not start WinMakerAppButtons
Start FvwmAnimate
Do not start FvwmAuto
Do not start FvwmBanner
Start Sounds Effect
Base Config: Used
This one decides which big buttons we start BarButtons, Wharf or None
#Read .start-FvwmButtons
If this is commented out in startup why are FvwmButtons
still starting?
and; “ChangeAppsMan WinListDesk” why does this command in “menus” turn them off?
Thanks gott; Well the thing I want to stop, I probably have the wrong name, is the “norm” icons lining up in an Icon box at the bottom of the screen.
Is this why it’s starting?
AddToFunc StartFunction I FvwmButtons DeskerPanelButtons
(if I take out the FvwmButtons part the Desker isn’t visible.)
Here is a clip from the top of my .fvwm2rc-wm-icons, If i comment these out they just end up in a pile, of course.
#i think this next 3 line makes the icons iconify to lower left
Style * IconBox 10 -80 -0 -0, IconGrid 64 64, IconFill left bottom,
IconBox 10 +300 -150 -80, IconGrid 64 64, IconFill bottom left
Style * SlipperyIcon, IconTitle
