I can see on the FVWM News page that the FvwmWinList module has been removed from FVWM 2.6.7 and one should use the WindowList command instead. I’ve tried to use this command in my fvwmrc, but all what I get is a popup, not a window like what the FvwmWinList module gave. How should the WindowList command be used as a replacement for FvwmWinList?
FYI, here’s my current configuration for FvwmWinList:
I’ve started to look at this. I can use WindowList TearOffImmediately to generate a tear off menu (though TearOffImmediately is only specified for the Menu and Popup commands in the fvwm man page). But anyway, new windows are not added to the WindowList menu unlike with the FvwmWinList module. So, that’s rather useless.
However, FvwmIconMan already has its own window by default, so that this module really seems to be the replacement for FvwmWinList. So, concerning the replacement for the FvwmWinList module, I wonder why WindowList is suggested instead of FvwmIconMan.
