In this function the follwoing capitals are used:
DestroyFunc FuncFvwmMaximize
AddToFunc FuncFvwmMaximize
M Maximize
H Maximize
C Maximize
D Maximize
Are the build-in constants or are they meant to be user defined somewhere?
Where can I find more info on details like this? I have looked in:
fvwm.org/documentation/manpages/stable/
But have no idea on where to look.
M == Motion, i.e. when something is Moved.
H == Hold, i.e. if a button pressed remains so on the window.
C == A single click.
D == A Double click.
They’re built-in constraints. And they’re listed in the manpage.
Thank you
I now they would be listed in the man pages, but if I write “man fvwm” I get a document so large that it would take me forever so go it through.
It is a big document, yes. You do realise that you can search for things in it? Once the man page has loaded, if you press:
You can then type in a keyword you want, and keep pressing ‘/’ and Return to move through all the items.
I can only use / when I am in KDE. For some reason that does not work in fvwm.
BTW: What did you search for in the man pages to find a description of H, M, C etc. I have tried (in KDE) to search for mouse but that is to general. What is the keyword for these constants??
Admittedly I didn’t look in the manpage. But any standard pager will support the keystroke I mentioned. The relevant part of what you want is thus:
The name must not contain embedded whitespace. No guarantees are made whether function names with
embedded whitespace work or not. This behavior may also change in the future without further notice. The letter before the action tells what kind of action triggers the command which follows it. ‘I’ stands for “Immediate”, and is executed as soon as the function is invoked. ‘M’ stands for “Motion”, i.e. if the user starts moving the mouse. ‘C’ stands for “Click”, i.e., if the user
presses and releases the mouse. ‘H’ stands for “Hold”, i.e. if the user presses a mouse button and holds it down for more than ClickTime milliseconds. ‘D’ stands for “Double-click”. The action ‘I’
causes an action to be performed on the button-press, if the function is invoked with prior knowl-edge of which window to act on.
