what is __PIXMAP__
I found in some config files PIXMAP variable. What does it mean? I couldn’t find info in fvwm manuals.
Namely I would like to do something like this
[code]AddToFunc FuncFvwmMenuDirectory
  • I PipeRead “fvwm-menu-directory -d ‘$0’ --icon-file PIXMAP
AddToMenu SomeMenu MissingSubmenuFunction FuncFvwmMenuDirectory
  • “Wallpapers Directory” Popup $[fvwm_wallpapers_th][/code]
That is menu with thumbnails of all papers in wallpapers_th directory and their filenames. However it does not work since I get “couldn’t load image from PIXMAP
That should get interpolated out by the Makefile which copies those files in place. I don’t know where you’re getting this file from, but it’s clearly straight out of CVS, most likely.
Here are some examples including PIXMAP in fvwm-menu-directry:
  1. line 1017
    git.sysphere.org/dotfiles/tree/fvwm/fvwm2rc
  2. bzsparks.com/fvwm/fvwm2rc
I couldn’t find any Makefiles.
Thank you.
