I did not see any relevant messages in the error log. The error log is attached below in case you don’t trust my assessment of relevance. Note that I also tried replacing xtrlock with a script
#!/bin/sh
echo locking >> /tmp/lock.log
xtrlock >> /tmp/lock.log
echo done locking >> /tmp/lock.log
to make sure that it was actually running. I pressed Scroll Lock repeatedly. You can see that the script ran by inspecting /tmp/lock.log which has this in it:
locking
done locking
locking
done locking
locking
done locking
locking
done locking
locking
done locking
locking
done locking
locking
done locking
locking
done locking
locking
done locking
locking
done locking
locking
done locking
(additional lines deleted)
Things appear to be weird than I realized: In the process of running this test to produce a well documented error log for you I discovered that if I press Scroll Lock rapidly in succession the xtrlock program sometimes actually locks the screen. A quick test of a sequence of double pressing Scroll Lock I observed it to lock 5 times out of 20 sets of double presses. (By “double press” I mean press, release, press, release as quickly as possible.) A sequence of 40 single presses never caused it to lock. Triple pressing seems to reliably lock.
The .xsession-errors file starting from an FVWM restart:
(pavucontrol:29509): Gdk-WARNING **: The program 'pavucontrol' received an X Window System error.
This probably reflects a bug in the program.
The error was 'BadWindow (invalid Window parameter)'.
(Details: serial 10163955 error_code 3 request_code 18 minor_code 0)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the --sync command line
option to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the gdk_x_error() function.)
[fvwm][ReadDecorFace]: <<ERROR>> unknown button face flag 'HiddenHandles,' -- line: -- HiddenHandles, NoInset
[fvwm][FlocaleGetFontSet]: (-adobe-times-bold-r-normal--14-140-75-75-p-77-iso8859-1) Missing font charsets:
ISO8859-2, ISO8859-3, ISO8859-4, ISO8859-5, KOI8-R, ISO8859-7, ISO8859-9, ISO8859-13, ISO8859-14, ISO8859-15, JISX0208.1983-0, KSC5601.1987-0, GB2312.1980-0, JISX0201.1976-0, ISO10646-1
[FvwmIconMan][FlocaleGetFontSet]: (-adobe-helvetica-medium-r-normal--12-120-75-75-p-67-iso8859-1) Missing font charsets:
[buttonbar][FlocaleGetFontSet]: (fixed) Missing font charsets:
[termbutton][FlocaleGetFontSet]: (fixed) Missing font charsets:
[soundcontrol][FlocaleGetFontSet]: (fixed) Missing font charsets:
[units][FlocaleGetFontSet]: (fixed) Missing font charsets:
** (pavucontrol:32765): DEBUG: Ignoring sink-input due to it being designated as an event and thus handled by the Event widget
** (pavucontrol:32765): DEBUG: Failed to initialize device manager extension: No such extension
