I have made a bar of buttons which bring up panels that contain things like an xterm, a volume control app, etc. I wanted to make a button that controls the print manager. The print manager raises itself when somebody prints, and I wanted to keep this behavior. In order to do that, I need a different sort of button, one that acts more like an icon manager button. Is there a way to create this button? I searched through the manual but can’t figure out how I can send the RaiseLower command to a certain window. I had the idea of swallowing an instance of FVWMIconMan that only manages one window, though that seems like an overly complex approach. What is the best way to do this?
Be more specific if you can. But what you’re asking for is this:
Next (SomeApplicationClass) RaiseLower
That seems to be just what I needed—it’s working just like I wanted. The whole button bar is as shown below. It would be nice if I could find a pulseaudio volume control program that doesn’t require such a huge window, but other than that I think I’m happy with how it is working. (Note that “blankshell” is a script that invokes the tcsh shell with an environment variable to create a short prompt. Is there a way to pass an environment variable in from fvwm without needing a wrapper script?)
Style FvwmButtons !Title, !Handles, CirculateSkip, NeverFocus, Sticky, \
WindowListSkip
Style *bar* !Handles, !Borders, SloppyFocus
Style units NoTitle, NoHandles, !Borders, SloppyFocus
Style termbutton NoTitle, NoHandles, !Borders, SloppyFocus
DestroyModuleConfig termbutton: *
*termbutton: Rows 1
*termbutton: Columns 1
*termbutton: (1x1 swallow(UseOld,NoHints,Respawn) "button_term" \
"Exec xterm -T button_term -bg lightcyan +sb -e tcsh")
DestroyModuleConfig units: *
*units: Rows 1
*units: Columns 1
*units: (1x1 swallow(UseOld,NoHints,Respawn) "unitswindow" \
"Exec xterm -T unitswindow -bg '#FED8A7' +sb -e units")
DestroyModuleConfig soundcontrol: *
*soundcontrol: Rows 1
*soundcontrol: Columns 1
*soundcontrol: (1x1 swallow(UseOld,Respawn) "Volume Control" \
"Exec pavucontrol")
DestroyModuleConfig buttonbar: *
*buttonbar: Rows 1
*buttonbar: Columns 12
*buttonbar: Back thistle
*buttonbar: (8x1 swallow (UseOld,NoHints,Respawn) "singleterm" \
"Exec xterm -T singleterm -bg thistle -fg black +sb -e blankshell")
*buttonbar: (Panel(steps 0,down,indicator,position button right) termbutton \
"Module FvwmButtons -g 300x150 termbutton")
*buttonbar: (Panel(steps 0,down,indicator,position button left) units \
"Module FvwmButtons -g 300x150 units")
*buttonbar: (Padding 0 0,Icon /home/adrian/.fvwm/notes.png,\
Panel(steps 0,down) soundcontrol \
"Module FvwmButtons -g 600x900 soundcontrol")
*buttonbar: (Padding 0 0, Icon /home/adrian/.fvwm/printer.png) \
Action (Mouse 1) "Next (Turboprint-monitor) RaiseLower"
FvwmButtons -g 300x22+800+0 buttonbar
Actually I encountered puzzling behavior. I wanted to make the print manager window always cover all other windows and I wanted it sticky. I used the following:
Style "turboprint-monitor" !Title, !Handles, Sticky, StaysOnTop, WindowListSkip
This works fine for xclock and xbuffy and the pager. But it doesn’t work for the print monitor. I tried changing StaysOnTop to “Layer 8” but that didn’t work either. I know that the window is getting the style because I observe it to vanish from the window list, lose its title, and turn sticky. But I can cover it with other ordinary windows. What could explain the failure of StaysOnTop?
This will depend when the value of the environment variable is set, and whose responsibility it is to set it. Basic process management knowledge will tell you that exporting variables from the shell is not a shared memory environment – children cannot update their parent’s knowledge of environment variables, in the same way that processes started from FVWM which set environment variables won’t be seen by FVWM.
If this is a more general thing though, Adrian, do have a look at FVWM’s SetEnv command.
Use !Title and !Handles throughout.
It’s probably a problem between the keyboard and the chair, but post your entire FVWM config somewhere and I can take a look.
I restarted X, rather than just restarting FVWM, and now the window is behaving as expected. I’m not sure why that should matter, but I guess that means the problem is solved.
No, it means something else entirely. Don’t be so presumptuous.
Ah, so what does it mean?
That there might be something in your config, hence why I asked for it before.
Please don’t drag me round in circles, it’s irritating.
### BUTTONS & CURSORS
#ButtonStyle 3 Vector 9 50x25@0 67x33@0 75x50@0 67x67@0 50x75@0 33x67@0 25x50@0 33x33@1 50x25@1
#ButtonStyle 4 Vector 9 50x25@0 67x33@0 75x50@0 67x67@0 50x75@0 33x67@0 25x50@0 33x33@0 50x25@0
#ButtonStyle 5 Vector 7 70x0@0 70x70@0 0x70@0 0x40@0 40x40@0 40x0@0 70x0@0
#ButtonStyle 6 Vector 8 40x20@1 40x50@1 20x50@1 50x80@1 80x50@0 60x50@0 60x20@0 40x20@1
ButtonStyle 1 Vector 4 50x75@1 25x25@1 75x25@1 50x75@0
ButtonStyle 2 Vector 7 70x0@0 70x70@0 0x70@0 0x40@1 40x40@1 40x0@1 70x0@1
### OPTIONS
DeskTopSize 2x2
EdgeScroll 100 100 wrap
EdgeResistance 500
Style * EdgeMoveDelay 50
Style * EdgeMoveResistance 50
Style * SnapAttraction 5
#old WindowFont -*-lucida-medium-r-*-*-12-*-*-*-*-*-*-*
#WindowFont -adobe-times-bold-r-normal--14-140-75-75-p-77-iso8859-1
#MenuStyle white grey SlateGrey 9x15 fvwm
MenuStyle * "fvwm", Foreground "white", Background "grey", Greyed "SlateGrey", Font "9x15", "AnimationOff"
OpaqueMoveSize 0
ClickTime 200
#CursorStyle TITLE 0
#CursorStyle RIGHT 24
#CursorStyle Root 0
### STYLES
TitleStyle LeftJustified
TitleStyle -- Flat
ButtonStyle All -- Flat
BorderStyle Active -- HiddenHandles, NoInset
Style * HilightFore black
Style * HilightBack PowderBlue
Style * IconFont -*-lucida-medium-r-*-*-14-*-*-*-*-*-*-*
Style * Font -adobe-times-bold-r-normal--14-140-75-75-p-77-iso8859-1
Style * Color black/grey
Style * !Handles, BorderWidth 4, NoIcon
Style * DecorateTransient, NoPPosition, HintOverride
Style * TileCascadePlacement, SloppyFocus
Style * RaiseTransient, LowerTransient
Style "Fvwm*" !Title, !Handles, Sticky, WindowListSkip, StaysOnTop
Style "Fvwm*" BorderWidth 1
Style "FvwmForm-Talk" Title, Slippery, WindowListHit, BorderWidth 4, StaysPut
Style "xbiff" !Title, !Handles, Sticky, StaysOnTop, WindowListSkip
Style "xbuffy" !Title, !Handles, Sticky, StaysOnTop, WindowListSkip
Style "myxclock" !Title, !Handles, Sticky, StaysOnTop, WindowListSkip
Style "xload" !Title, !Handles, Sticky
Style "turboprint-monitor" Sticky, StaysOnTop, WindowListSkip,!Closable
Read /etc/X11/fvwm/menudefs.hook
### POPUP MENUS
DestroyMenu RootMenu
AddToMenu RootMenu
+ "Root Menu" Title
+ "xterm" Exec xterm &
+ "Applications" PopUp Apps
+ "X functions" PopUp XStuff
+ "All Programs" PopUp "/Debian"
+ "Desktop" PopUp Desk_Ops
+ "Lock" Exec xtrlock &
# + "Log out" PopUp Logout_Menu
DestroyMenu Apps
AddToMenu Apps
+ "firefox" Exec firefox &
+ "mail" Exec xterm -geometry 80x60 -e mutt &
+ "gnucash" Exec gnucash &
+ "top" Exec xterm -T top -n top -geometry 80x60 -e top &
+ "emacs" Exec emacs &
#+ "console" Exec /xterm -geometry 80x7+1+1 -C -T `hostname` &
DestroyMenu XStuff
AddToMenu XStuff
+ "editres" Exec editres &
+ "X colors" Exec xcolors &
+ "X events" Exec /usr/bin/xterm -e xev &
+ "X cut buffers" Exec xcb &
DestroyMenu "Bar_Ops"
AddToMenu "Bar_Ops"
+ "Hide" Iconify
+ "Lower" Lower
+ "" Nop
+ "Move" Move
+ "Resize" Resize
+ "" Nop
+ "Big" Maximize
+ "Tall" Maximize 0 100
+ "Wide" Maximize 100 0
+ "Medium" Maximize 700p 800p
+ "" Nop
+ "Stick" Stick
+ "Identify" Module FvwmIdent
+ "" Nop
+ "Close" Close
DestroyMenu "Logout_Menu"
AddToMenu "Logout_Menu"
+ "Log Out Menu" Title
+ "Log Out" Quit
+ "Don't Log Out" Nop
+ "" Nop
+ "Suspend" Exec /usr/sbin/s2ram
DestroyMenu "Desk_Ops"
AddToMenu "Desk_Ops"
+ "Refresh" Refresh
+ "Reload Resources" Exec xrdb $HOME/.Xresources &
+ "" Nop
+ "Show Pager" Module FvwmPager 0 0
+ "Hide Pager" KillModule FvwmPager
+ "" Nop
+ "Show Icon Mgr" Module FvwmIconMan
+ "Hide Icon Mgr" KillModule FvwmIconMan
+ "" Nop
+ "Print selection" Exec xcb -p 0 | enscript -2Gr -Plp600 2>/dev/null
+ "Print window" Exec xwd | xwdtopnm 2>/dev/null | lpr
+ "" Nop
+ "Mouse speed" PopUp Set_Mouse
+ "" Nop
+ "Talk to Fvwm" Module FvwmTalk
+ "Restart Fvwm" Restart
+ "Destroy window" Destroy
DestroyMenu "Set_Mouse"
AddToMenu "Set_Mouse"
+ "Very Fast" Exec xset m 7 10
+ "Fast" Exec xset m 3 10
+ "Default" Exec xset m default
+ "Glacial" Exec xset m 0 10
### MOUSE BINDINGS
# Window bar button actions
Mouse 0 1 a Iconify
Mouse 0 2 a Resize
# Window bar and border actions
Mouse 1 fst a Move-or-Raise
Mouse 2 fst a Resize
Mouse 3 fst a Menu "Bar_Ops" Nop
# root window actions
IgnoreModifiers L2
Mouse 1 r a XtermOrMenu
Mouse 2 r a Windowlist
Mouse 3 r n Menu "RootMenu" Nop
#Mouse 3 r n2 Menu "RootMenu" Nop
Mouse 3 r c Menu "LogOut_Menu" Nop
#Mouse 3 r c2 Menu "LogOut_Menu" Nop
DestroyFunc XtermOrMenu
AddToFunc XtermOrMenu
+ C Exec xterm &
+ H Menu Apps Nop
### MODULES
*FvwmPagerGeometry 60x40-0+0
*FvwmPagerRows 1
*FvwmPagerColumns 1
*FvwmPagerFont none
*FvwmPagerFore black
*FvwmPagerBack grey
*FvwmPagerHilight DeepSkyBlue4
# With bigger pager, can get name of window on little copies:
# *FvwmPagerSmallFont -misc-fixed-medium-r-normal--7-70-75-75-c-50-iso8859-1
*FvwmIconMan*background thistle
*FvwmIconMan*foreground black
*FvwmIconMan*plainbutton up
*FvwmIconMan*followfocus true
*FvwmIconMan*selectbutton flat magenta thistle
*FvwmIconMan*iconbutton up
*FvwmIconMan*focusbutton up blue thistle
*FvwmIconMan*managergeometry 1x0-1+42
*FvwmIconMan*buttongeometry 150x0
*FvwmIconMan*format "%t"
*FvwmIconMan*font -adobe-helvetica-medium-r-normal--12-120-75-75-p-67-iso8859-1
*FvwmIconMan*resolution global
*FvwmIconMan*action Mouse 1 a sendcommand Iconify
*FvwmIconMan*action Mouse 2 a sendcommand "Move pointer"
*FvwmIconMan*action Mouse 3 a sendcommand "Module FvwmIdent"
*FvwmIdentBack grey
DestroyModuleConfig mpdbar: *
*mpdbar: Back darkgrey
*mpdbar: Columns 5
*mpdbar: Rows 2
*mpdbar: (1x1, Action (Mouse 1) 'Exec mpc play &>/dev/null', Icon \
$[HOME]/.fvwm/icons/play.png)
*mpdbar: (1x1, Action (Mouse 1) 'Exec mpc pause &>/dev/null', Icon \
$[HOME]/.fvwm/icons/pause.png)
*mpdbar: (1x1, Action (Mouse 1) 'Exec mpc stop &>/dev/null', Icon \
$[HOME]/.fvwm/icons/stop.png)
*mpdbar: (1x1, Action (Mouse 1) 'Exec mpc prev &>/dev/null', Icon \
$[HOME]/.fvwm/icons/prev.png)
*mpdbar: (1x1, Action (Mouse 1) 'Exec mpc next &>/dev/null', Icon \
$[HOME]/.fvwm/icons/next.png)
*mpdbar: (5x1)
WindowListSkip
Style units !Title, !Handles, !Borders, SloppyFocus
Style termbutton !Title, !Handles, !Borders, SloppyFocus
*termbutton: Rows 1
*units: Rows 1
*units: Columns 1
"Exec pavucontrol")
*buttonbar: Rows 1
Action (Mouse 1) "Next (Turboprint-monitor) Iconify"
AddToFunc Move-or-Raise "C" Raise
+ "M" Move
AddToFunc PrintFunction "I" Raise
+ "I" Exec xwd -silent -id $w | xwdtopnm | lpr
Key Print W N PrintFunction
Key F1 W C Destroy
Key F12 W A Maximize 800p 900p
### INIT
AddToFunc InitFunction
+ I Exec /usr/local/bin/myxclock -padding 3 -geometry -113+1 -d \
-font '-adobe-courier-bold-r-normal-*-20-*-100-100-m-*-iso8859-1' &
+ I Exec /usr/bin/xbuffy -g 44x27-61+0 -horiz -boxfile ~/.mailboxes
+ I Exec xterm -geometry 80x62+1-1 &
+ I Exec xconsole -file /dev/xconsole -geometry 480x96+0+0 &
+ I Exec turboprint-monitor -iconic &
+ I Exec xsetroot -solid gray35 -def
+ I Exec xhost +
+ I Exec /usr/local/bin/argyll/dispwin -I /etc/calibration/data.icc
DestroyFunc StartFunction
AddToFunc StartFunction
+ I Module FvwmPager 0 0
+ I Module FvwmButtons -g 300x22+800+0 buttonbar
+ I Module FvwmIconMan
