Hi!
Please can you look on my skript, whats going wrong with it. This Applet is swallowed in my FvwmButton and shows me the state of my UMTS-modem, my external HD and the status of the Backup on this HD (HD is busy with backup or not), and the state of fetchmail and fetchnews. It also changes the Title of the Button in FvwmButton for the Volume-Control, so that i have always the right volume in it.
This applet works fine. But it takes more and more memory and cpu. after 4, 5 hours top shows me, that it needs 30% mem, and the same cpu-time… but i cannot find a variable or a loop, which counts up and is not beeing reset…
ps auxf shows nor further process after the process for this script!
The script:
WindowTitle {FvwmApplet-kppp}
WindowSize 60 16
Font “Shadow=0 1 SE:xft:Bitstream Dejavu Sans Mono:style=Roman:size=6”
#Font --lucida-bold-r-normal--10------
Use the FvwmScript default colors.
BackColor {#c6c3c6}
#ForeColor {black}
#ShadowColor {black}
#HilightColor {rgb:a0/90/80}
Init
Begin
If $MainColorset <> {} Then
Begin
ChangeColorset 2 $MainColorset
ChangeColorset 3 $MainColorset
End
Set $mars = 0
Set $ppp = 0
Set $umts = 0
Set $rsnap = 0
Set $pidoffnews = 0
Set $pidoffmail = 0
Set $fmail = 0
Set $fetchstat = 0
Set $volume_set = 0
Set $mute_set = “”
End
PeriodicTasks
Begin
If (RemainderOfDiv (GetTime) 1)==0 Then
Begin
Set $pidoffnews = 0
Set $pidoffmail = 0
Set $fmail = 0
Set $fetchstat = 0
Set $umts = (GetOutput {test -e /dev/umts0 && echo 1 || echo 0} 1 1)
Set $ppp = (GetOutput {test -e /var/run/ppp0.pid && echo 1 || echo 0} 1 1)
Set $mars = (GetOutput {test -e /dev/disk/mars && echo 1 || echo 0} 1 1)
Set $rsnap = (GetOutput {test -e /var/run/rsnapshot.pid && echo 1 || echo 0} 1 1)
Set $pidoffnews = (GetOutput {/bin/pidof fetchnews} 1 1)
Set $pidoffmail = (GetOutput {/bin/pidof fetchmail} 1 1)
Set $volume = (GetOutput {amixer sget Master|grep “%”|sed -e ‘s/^.[([0-9])%.$/\1/g’} 1 1)
Set $mute = (GetOutput {amixer sget Master|grep “%”|sed -e 's/^.(on|off).*$/\1/g’} 1 1)
If $pidoffmail <> {} Then
Set $fmail = (GetOutput {grep SigIgn /proc/$(pidof fetchmail)/status|cut -c 22} 1 1)
Do {echo } $volume { } $mute
If $pidoffnews <> {} Then
Set $fnews = 1
Else
Begin
Set $fnews = 0
End
If (Add $fnews $fmail) > 0 Then
Set $fstat = 1
Else
Begin
Set $fstat = 0
End
Do {exec echo } $fstat { } $fnews { } $fmail { } $pidoffnews { } $pidoffmail { } $umts { } $ppp { } $mars { } $rsnap { } $volume { } $mute
If $umts == 1 Then
Begin
If $ppp == 1 Then
Else
Begin
End
End
Else
Begin
End
If $mars == 1 Then
Begin
If $rsnap == 1 Then
ChangeIcon 2 disk-achtung.xpm
Else
Begin
ChangeIcon 2 disk-on.xpm
End
End
Else
Begin
ChangeIcon 2 disk-off.xpm
End
End
If $fstat == 1 Then
Else
Begin
End
#ChangeTitle 3 $fnews
If $volume_set == $volume Then
Set $chvol = 0
Else
Begin
Set $chvol = 1
Set $volume_set = $volume
End
If $mute_set == $mute Then
Set $chmute = 0
Else
Begin
Set $chvol =1
Set $chmute = 1
Set $mute_set = $mute
Set $tit = “Mute”
End
If $mute == on Then
Begin
If $chvol == 1 Then
Begin
If $volume == 0 Then
Do {CHANGE_ICON Vol audio-volume-muted.png}
If $volume > 0 Then
Do {CHANGE_ICON Vol audio-volume-low.png}
If $volume >= 33 Then
Do {CHANGE_ICON Vol audio-volume-medium.png}
If $volume >= 66 Then
Do {CHANGE_ICON Vol audio-volume-high.png}
Do {CHANGE_TITLE Vol Volume (} $volume {%)}
End
End
Else
Begin
If $chmute == 1 Then
Do {CHANGE_TITLE Vol (} $volume $mute {%)}
End
End
Widget 1
status von ppp/umts
Property
Position 2 0
Size 16 16
Type ItemDraw
Flags NoReliefString
Title {orange|orange}
Main
Case message of
SingleClic :
Begin
Do {Function PPPconnect}
End
End
Widget 2
#status von rsnapshot
Property
Position 22 0
Size 16 16
Type ItemDraw
Title {""|mount-mars|umount-mars}
Icon disk.xpm
Main
Case message of
SingleClic :
Begin
If $rsnap == 1 Then
Do {Function KillMkBackUp}
Else
Do {Function StartMkBackUp}
End
End
Widget 3
#status von fetchnews
Property
Position 42 0
Size 16 16
Type ItemDraw
Type PushButton
Title {“1”|“mount-mars”|“umount-mars”}
Main
Case message of
SingleClic :
Begin
Do FetchMailNews
End
End
