…this leaves the first of the buttons contents centered, but the second one has its contents right justified. “Right” on the first one also leaves is centered. What am I doing wrong???
it seems when you have a “swallowed” fvwmscript that changes the title dynamically. the justification doesnt work at all, everything gets centered…
It works fine when I set the title manually.
This is most likely an intentional side-effect from using SendToModule to change the title of a button dynamically. I’ll look at the code later to determine if this is so.
