ngeo
1
Hi !
I launch two xterm one with a ‘top d 0.5’
and i’m resizing the other one. The ‘top’ does not
update while i keep the resize handle.
(It seems to me that all other applications are frozen).
There is a bug in incoming talking about --disable-ewmh
but this option is no more available.
Do you know a way to have other applications updating their
display while resizing ? Even if i loose other functionalities…
Thank you for your help.
Ngeo.
Why does it matter? This is a side-effect in the way the resize operation worls.
ngeo
3
It matters, because my application won’t update while
resizing and i could not allow this.
But i found a way to bypass my problem.
Other application are not frozen if i use ResizeOpaque instead
of ResizeOutline.
Thanks for your answer.
Ngeo.
Right – I see what you mean. It wasn’t clear what you were meaning.
