i have problem with fvwm when i startx desktop manager don’t visible background i black but our bar panel is visible. can u help me pls i use gentoo
Well, the background is probably not in the config, so you’re going to edit the config to have the background setting utility point to a valid image.
no man image link is correct but the desktop manager isn’t work
I just downloaded the pack and in the config it says:
He uses “fbsetbg” to set the wallpaper,so you have to install “fluxbox” to use the command or install “Eterm” and use the command “Esetroot” which would be easier.
Also make sure you have the wallpaper in the correct place like theBlackDragon says.
