Al. You are my god. I need your help. your the only one with the power.
Now, onto my stuff:
Gentoo user (w00t) and loving every minute of it. (can you? emerge love?) anywho. I was looking at your screenies. and Ive decieded. I really would like to copy some of the things you do. Can you help me out, by pointing me in the right direction. I would like to (desperately) have a terminal “Run as the background image” so you have Elisha Cuthbert on your desktop (alunt2003.homelinux.org/pics/april.jpg) up in the right hand corner, you have some emerge business, but NO frame around it. [ solved - no title, borderWidth 0, No handle ] How?? I mean WFT??? its like MAGIC. I really would like to do that (seeing as how I run gentoo and all, you know the Command line business). then the bottom left business, of uptime, ram, volume and all that. (I assume thats gdesklets? but I havent worked with them before - my roomate has)
Also, a little run down. Ive been a hardcore linux user for over a year. I would consider myself somewhat advanced. So I dont need my hand held, just a huge shove in the right direction. Websites, tutorials, an IM?? who knows…
These aren’t strictly transparent but if you read the man pages or do a search of the Gentoo forums you will find loads of examples such as this one i just found:
aterm -tr -sr -trsb -sl 5000 -title "Gentoo Terminal" -fn 9x15 -fb 9x15 -fg white -cr black -geometry 80x40
What’s the name of the theme you are using for the decorations on your latest screenshot? (i.e. this one ). Are they part of the fvwm.zip pack available on your Linux page?
Changed to an osx bar at the bottom.Added a clock and moved them to the left so i can place Gaim to the right.
Stripped the icons from the menu for a smaller menu and changed the font to “aquafont”.
I would like to add a date applet next but i’m pushed for room on this 15" screen.
One of the best configs/screenshots in a while! Congrats!
I love the new titlebar style and buttonbar!
For your date applet, couldn’t you hack whatever you are using to display the time in that little FvwmButtons box so it would display the date also? I believe Gulivert has donne something similar in v1.5 of his config…
Any chance you will make your config and images available?
that archive unfortunately does not contain the .fvwmrc.
I looked through the thrads here, but did not find out yet how to create round edges on titlebars like you do with firefox on your screenshot: alunt2003.homelinux.org/pics/screen01012005.png
You can’t, alas. Rounded corners on windows are not something you can do easily – if at all. The “best” solution at present is to shape mask fvwmbuttons and have that swallow your applications…
al our screenshout very nice. what is the configure packet for jun screenshout? and what are the steps for installing our conf? help me pls i’m newbie in fvwm. byez
