Ok so heres the new panel (mpd)
130.232.30.60:3800/FvwmApplet-MP … .3.tar.bz2
And the screenshot is the same as in my previous post:
130.232.30.60:3800/FvwmApplet-MPDPanel-0.2.png
Wrong version number on the pic but that’s not really important now is it ?
Have tested it and everything should work
By opening the FvwmApplet-MPDPanel file in your favorite editor you can find, almost in the beginning, some comments and variables you might want to change
by uncommenting either
ChangeIcon 1 mpd/null.png
ChangeIcon 19 mpd/null.png
of these you can change how the interface looks…
Widget 1 is the frame for the buttons, widget 19 is the frame for the song text…
EDIT: Just realized i should maybe make the buttons a lil’ bit bigger? like now they’re only the size that they have content in them, eg if you click 1pixel above the play button (still inside the frame if it’s on) it will not do anything
