I think this question was asked before, but I couldn’t find it…
So, is it somehow possible to get an animation at the startup of fvwm?
If I have ~10 pictures and wanted to produce an animation of them reflecting the loading process of fvwm, could it be done with fvwm tools?
Look at the “AnotherLevelUp” package — this changes backgrounds as it loads to reflect loading-status.
Thanks Thomas. (you know, you should really consider putting a phpbb -title “guru” for yourself )
I took the sources for AnotherLevelUp, and looking at the content, I’m not sure by what you meant was the corresponding function? I see init-screen-picture* 's, but I’m not entirely sure if they’re the ones used for the loading screen?
It seems this is very complicated stuff with AnotherLevelUp (I hope they move to fvwm-themes ASAP ), so I would greatly appreciate if you could point out exactly what I should be looking for!
Heavens, no.
That’s right – as you can see, what’s happening is that at each state of the configuration loading, the background is changed (via ‘display’ from ImageMagick). Now, AnotherLevelUp (like AnotherLevel) uses M4 – which is probably where some of the confusion arises. I suppose you could do something like this:
AddToFunc StartFunction
+ I foo
+ I bar
Although to be quite honest this would slow things down. Even without using schedule, FVWM tends to load damn fast anyway.
Well, AnotherLevelUp has been around a loooong time prior to fvwm-themes… (I used to use a heavily customised version of the original RH version of ‘AnotherLevel’ using the Lesstif version, of course.
Yeah, too fast occasionally …
Just out of curiosity, could the same thing be achieved with FvwmScript? Ie., not the whole background, just a predefined size window?
You sick, sick puppy
Probably. You might need ModuleSynchronous though – since the ordering would probably matter to you.
