I’ve got an annoying little problem with fvwm. The following error message is generated every time i switch desktop using GotoDesk:
[FVWM.0][__execute_function]: <<ERROR>> No such command '0'
[FVWM.0][__execute_function]: <<ERROR>> No such command '1'
[FVWM.0][__execute_function]: <<ERROR>> No such command '2'
[FVWM.0][__execute_function]: <<ERROR>> No such command '3'
Switching to desktop 1 generates the first line, to the second desktop generates the second one and so on.
I have the following keyboard shortcuts defined:
Key 1 A 4 GotoDesk 0 0
Key 2 A 4 GotoDesk 0 1
Key 3 A 4 GotoDesk 0 2
Key 4 A 4 GotoDesk 0 3
4 is the windows key.
Given that FVWM 2.5.18 has now been released, start using that. Note that I cannot reproduce your “bug” – if it is indeed even one, since although you get that error message, it still seems to work just fine.
If upgrading to 2.5.18 doesn’t solve it, let me know.
