zizban
15 October 2007 14:15
1
Hi
I am really new to this (like yesterday). I simply want to make my windows iconify in the upper right portion of the screen, then be able to deiconify. I found this:
[code]DestroyModuleConfig FE-ArrangeIcons:*
*FE-ArrangeIcons: iconify “All (Iconic, CurrentPage) PlaceAgain Icon”
*FE-ArrangeIcons: deiconify “All (Iconic, CurrentPage) PlaceAgain Icon”
AddToFunc StartFunction I Module FvwmEvent FE-ArrangeIcons[/code]
Only it doesn’t deiconify
Here is my basic fvwm2rc so far:
[code]DestroyFunc StartFunction
Set autoraise
AddToFunction StartFunction
Icon Path
ImagePath ${HOME}/icons/:/usr/share/icons/${HOME)/icons/decor:+
A simple panel
I Module FvwmButtons FvwmButtons-Panel
style “FvwmButtons-Panel”
NoTitle,
BorderWidth 0,
handleWidth 0,
sticky
#*FvwmButtons-Panel: (Swallow “FvwmPager” “FvwmPager 0 0”)# I didn’t like this
*FvwmButtons-Panel: Columns 1
*FvwmButtons-Panel (1x1 Icon ‘firefox.png’
Action(Mouse 1) ‘exec exec firefox’
*FvwmButtons-Panel: (1x1 Icon ‘terminal.png’
Action(Mouse 1) ‘exec exec xterm’
*FvwmButtons-Panel: (1x1 Icon ‘dialog-warning.png’
Action(Mouse 1) ‘Module FvwmForm FvwmForm-QuitVerify’,
Action(Mouse 3) ‘restart’
Golbal Styles
Style “" MinOverlapPlacement
Style " ” BorderWidth 2, HandleWidth 2 #Defaults
Mouse 1 1 N Close
Mouse 1 4 N Iconify
Mouse 1 2 N Maximize
#Desktop size
DeskTopSize 1x1
#Icon Management
#[/code]
zizban:
Hi
That looks like something I would write.
Sure it does. Your config file defines these mouse bindings:
Mouse 1 1 N Close
Mouse 1 4 N Iconify
You’re missing one that operates on an iconic window, hence:
Mouse 0 I A Iconify
zizban
15 October 2007 15:35
3
I may have gotten from you, or one you helped write.
Okay, I added the second iconify line:
Style "*" MinOverlapPlacement
Style "*" BorderWidth 2, HandleWidth 2 #Defaults
Mouse 1 1 N Close
Mouse 1 4 N Iconify
Mouse 0 I A Iconify
But now none of my buttons work. The cursor just sits there, taunting me.
zizban
15 October 2007 17:32
4
Using this code I get the iconify/deiconify working. There are probably better ways.
#[code]####
FvwmEvent
*FvwmEvent: deiconify DeThumbnail[/code]
Now, is there a way to iconify in the upper right since my panel will be in the upper left?
zizban:
#[code]####
FvwmEvent
This depends entirely by what you mean when you say “not working”. Your sample fvwm2rc makes no reference of there being any way to deiconify a window. Using an explicit Mouse action like the one I gave you would work. The reason why it fails for you could be anyone’s guess, I’m guessing because you had numlock on.
Your “”“solution”“” of calling DeThumbnail works only because you’ve got a mechanism for deiconifying an application already. How that is, I don’t know. Your config doesn’t show that.
zizban
15 October 2007 18:04
6
The numlock! (slaps head) why didn’t I think of that?
Your config works great now, thank you!
So how I would it configure it so that my icons are on the upper right? (or heck anywhere else but the upper left where my panel is).
Because you didn’t know about it, or overlooked the obvious.
See the IconGrid, IconBox, and IconFill style conditions.
zizban
15 October 2007 18:31
8
What would I need to do to make it with the numlock on?
I will look into those other functions.
